To make it easier and quicker, there is no reason why it shouldnt be.My ? is was the dust cap glued to the recone before you put it on just wondering.
ummm, how did you get the shims out? or did you just "center" the coil in the gap by eye?To make it easier and quicker, there is no reason why it shouldnt be.
Im sure is sackett had it glued down then he knew it wouldnt need shims, he's been doing this long enough to know.Right see you need to shim the coil in the gap so it dont rub on the pole. Or them spiders are smaller then 8 in and fit in the next landing ring on that basket. To set the coil in the gap with out it hitting the pole you need to shim. if not its possabe to hit or when the sub moves up and down its surround dont move proper and deforms.
So you throw how many years youve been doing this into the mix to try to make yourself look right when it could go either way. Start a thread and ask how many people have used drop in re-cones without shims and shit. Some people use them and some dont, both ways obviously work or people wouldnt still be doing either option.Really ok good luck with it. ill stick to the way i have been doing it for 14yrs just trying to help ya out you need shims.
Well i guess you've never seen every drop in that has ever been sold have you ?its all good i know every drop in i seen the cap was never glued so they can shim it.
Not tryin to be a dick man, but why everytime someone posts do you have to down them about what they say?Well i guess you've never seen every drop in that has ever been sold have you ?
You have 2 posts and your going to assume that i put everyone down. Just to make you feel better im going to call you an idiot and tell you to read more and post less.Not tryin to be a dick man, but why everytime someone posts do you have to down them about what they say?
lulz. I never said it was. I know some drop ins do not require shims though. i thought it was pretty cute though.LMDAO!!!! tehworstest u fail..... hard. the dust cap was put on after everything was said and done. that is the last thing you do. you HAVE TO SHIM when doing a re-cone! lol there is no way of simply lining it up bye eye. haha
but sorry build was put on hold as fedex lost my amp i ordered off ebay. an audiopipe 1500d. if i dont get the amp and i am refunded on wed. then i will be purchasing a solid audio f15D from rev.
