Cup Terminals vs Direct Connection
  • 7
Jaguar
GA
Is there really a difference at all? If so, how? I can see how there could be a minimal amount of resistance of having the wires go through the terminals, but not enough to notice an improvement. Am I wrong? I was thinking of routing my subwoofers directly to my amp direct through the port or drilling holes bypassing the terminals until I get a new box, but is it worth it? Idk. Probably with some good terminals, it would not matter but currently I have these standard low grade terminals.
Advice.
Most people prefer it because when running 1.5k and up terminal cups have a tendency to melt. You also get less resistance and it is easier to use bigger wire since most terminal cups can't fit bigger than 12 gauge.
you wont notice a difference....
Ok. Maybe I wouldn't notice a difference, but let's take this to the next level, wouldn't it make a difference? What about cheap terminals vs higher end
terminals vs direct connection? Hm.. Idk. Obviously direct connection "owns", but what I'm trying to gage is how much cup terminals are responsible for
distortion/resistance. Would sound meters(octave band analyzer, fft analyzer, oscilloscope, spectrogram) be able to discern a noticeable difference?
What are the +'s and -'s when it gets down to it.
Ohms is ohms. If the terminals add resistance they can reduce current and therefore lower power. But we're talking less than a tenth of an ohm even for cheap terminals. Ain't gonna be measureable. A much bigger issue is as stated above - the heat generated by a poor connection can melt the plastic.
Copper bolts through the box work as well as anything, and they seal the holes. Available from big home stores. Personally I like the gold plated binding posts that Parts Express sells but they're expensive.
.. and please lose the bold and colors. Difficult for old eyes to read.
Ohms is ohms. If the terminals add resistance they can reduce current and therefore lower power. But we're talking less than a tenth of an ohm even for cheap terminals. Ain't gonna be measurable. A much bigger issue is as stated above - the heat generated by a poor connection can melt the plastic.
I feel you on this %100, however even though less than a tenth of a loss of an ohm can add up if there are other, even several other points of
weakness in the system as a whole. It's not only about the power but preserving the audio information. As the signal passes between current
and diaphragms when amplified, how well the signal is preserved is directly related to how clear the sound is when it is produced by speakers.
Preserving the audio information? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Lol we're talking about subwoofer boxes. It ain't rocket science.
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
I like the way these look. But whatever I do it has to be top post. My battery is on the driver side and right beside the air filter housing. So...
764
The way it is sitting doesn't seem unsound, just not neat and factory looking. You might be able to come 90 degrees out the side cut away some...
14
Im really glad I found this site, you've all taken time to help me out, much appreciated!!! I got a ported kicker brand box and 2 of those 12 sub...
A quick Google search, and I found this option. https://www.amazon.com/dp/B004QCBM28/?tag=caraudiocom-20
Jaguar
Jaguar
GA
Falcons
