HUGE Voltage drop when head unit turned on!!
Daipone
Hey everyone this is my first problem i face in my sound system i am not installer but i need to figure out the problem..
my electrical :
Mechman 200a + front optima yellow top + rear req battery ( 1/0 big 3 )
RE XXX 18" running 2600 Hifonics at 1-ohm and small pioneer amplifier for component speakers
with head unit off i have 14.2 volt in my voltmeter when i turn on the head unit the voltage dropped to 13.3 my amplifiers are work no problem but this is much current draw for idle amplifier i did't face this problem before do i have bad ground or bad remote wire i hope it's not somthing major
Sounds like bad ground id recheck the whole big 3 also check voltage with dmm at alt front batt , rear batt and amps this will help you figure out where the bad connection is
I notice somthing weird when i move the RCA behind my headunit my voltage get drop and increase am not sure if it's bad rca or bad ground
before my voltage 13.0 when i move some wire randomly now i got 13.6 weird Rca anybody tell me what's the problem
i use stinger voltmeter i did't face this problem before now it's weird my head unit draw 0.8 ampere but i move some wires and increased alil bit is it bad ground or rca problem my dashboard get allot of shakin during driving maybe somthing went wrong
Daipone
Daipone
Florida
Daipone
