Crossover Question?
  • 1
nofriends46
I have a Panasonic Head Unit, its has a subwoofer preamp outputs, also it has a feature to set the crossover to 80hz and 120hz and has a Bass gain from 0-8db.
Right now my headunit is set at 80hz and 3db gain, do i have to set my AMP CROSSOVER to 0hz since my head unit is set at 80hz? Or i just set my Amp and Head Unit at 80hz? Help!!! Thanks!
Yep. It would be a little over 3 wired in series, but that’s fine.
806
id start with 80, fine tune from there good test track...
8
12db is usually 180° out of phase if used left and right. 24db makes the full 360° phase change when running left and right. This is...
183
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
918
nofriends46
nofriends46
Hawaii, Kauai
nofriends46
pfft
    May 1, 2024
pfft
    May 1, 2024
Latest topics
