Crossover Question.
Crownvicon28s
God 1st
Ok. What I have decided to do is go with a 6.5'' sub and a 4'' midbass in each front door and run my rear fill off of the two rear channels of my amp. Each speaker is 4 ohms, thus each of the 2 front channels will see 2 ohms. If I was to use a 3 way crossover for the sub and midbass, would it change the impedence the amp sees? 4ch amp btw.
Yeah its a 3 way passive. I may go active later. After I get everything and get it installed. Seems like its alot to going active. Idk if im ready. lol. I may say forget it and try it anyway. We will see.
I have a semi-active setup, you might try it. I run my 8" mid-bass speakers from 80hz down. I run 6.5 and tweeter on a passive crossover on the "rear" channels of the amp full-pass.
Nothing has been said about the impedance your amp sees. When using a passive crossover, the amp doesn't see the speakers in parallel, it only sees one speaker at a time (plus the impedance the crossover adds).
Are you building the crossover yourself? What are the crossover points?
Crownvicon28s
God 1st
Crownvicon28s
Spartanburg, SC
keep_hope_alive
