bigsheep
I have a "Frankenstein" of a component setup. Using entry level Kicker 5x7s as mids and a pair of "I don't know the name" tweeters. The tweeters look like they were salvaged from some sort of factory setup. I am running bipolar capacitors on the tweeters. I think that they may be 10 microfarad. The tweets and mids are fed by an old school 4x60 Pioneer at 4 ohms. Using the amplifier's high pass filters set as high as possible for the tweets.
The problem is at excessive volume, the tweeters are cutting out. I suspect that the capacitors are overheating. Is there an easy way to cut off all frequencies above 17000 hertz? If I can filter these frequencies before the capacitors, I think that I can keep the caps from overheating.
The tweeters only shut off while playing a CD. I have no problems with Sirius. The Sirius is so grossly compressed that highs do not pose any problems.
Feel free to tell me to turn it down. I won't. I am old as dirt, deaf as a post, and as stubborn as a mule. I like it LOUD.
Sheep
Sheep
