cross over setting
Flipx99
Violator of Terms
26,283
Building 100
I have the type r 5.25 crossover set. I already had them from previous car but I decided to build door pods for these. They came out decent. I have a question about the crossover. SHould it be on 0 db, 3 db, or 6 db. I left it at 0 because that os factory but what does it do if you move it?
It just attenuetes the tweeter. Basically, it allows you to adjust the volume of the tweeter. If the crossovers aren't going to be too hard to get to, then you can always change the jumper settings later. However, if your mounting them in your doors, you should probably get everything hooked up first, and play a bunch of different music that you normally listen to, while flipping the jumper to various levels to see where you like it best. Then you can go ahead and mount the door panel, if its going to be hidden.
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif
This is not something we can answer over the 'net. Just set it to whatever sounds best. Plain and simple.
Check out Focal. I believe they have direct replacements for many Toyota's...
Make sure they provide a warranty for theyre work and everything you buy.Ask to keep all the Boxes that every amp and speaker and sub comes in...
It depends on the brands they want to use. I would go with speakers first. If they sound great on radio only, then I would add the amp and sub...
Flipx99
Violator of Terms
Flipx99
Building 100
squeak9798
    Apr 28, 2024
    Apr 28, 2024
