That all seems way more involved than i want to go...
and to RLJ676, here is the exerpt in the 300/4 manual for what i'm talking about...
"Even though you may have installed zillions of amps in your day, please take the time to read this section! The 300/4v2 is not a typical amplifier and care must be taken to balance the front and rear channel speaker impedances for optimum output from all four channels.
The 300/4v2 employs JL Audio’s exclusive Regulated, Intelligent Power Supply (R.I.P.S.)
design. This sophisticated power supply allows the amplifier to produce its optimum power (300 watts) over a wide range of speaker impedances. unlike conventional amplifiers that require a specific impedance to produce optimum power, the R.I.P.S.-equipped 300/4v2 gives you the
freedom to use a variety of speaker configurations that achieve final impedances between 1.5 – 4 ohms nominal per channel (without sacrificing power output or sound quality).
The operation of the R.I.P.S. circuitry is entirely automatic and adjusts itself every time the amplifier is turned on according to the lowest impedance present at either front or rear channels. There are no user controls to configure. The system operates through three stages of impedance optimization, choosing the stage most appropriate to the actual impedance of the speakers connected to it.
Because the 300/4v2 utilizes a single power supply, it will set itself up based on the lowest impedance present at either the front or rear amplifier channels. For example, if you connect a 2 ohm load to each front channel and a 4 ohm load to each rear channel, the amplifier will adjust itself to deliver 75 watts x 2 to the front 2 ohm loads, but will only deliver half its optimum power (37.5 watts x 2) to the rear 4 ohm loads. If you connect a 4 ohm load to all four channels or a 2 ohm load to all four channels, the amplifier will deliver 75 watts x 4. See, we told you this amp was different... Read on, there is more important information to follow."
