CRD Mazda CX-7 SQ Install
A little update on the Amp Rack, I didn't did much on the amp rack only fixing the frame, this amp frame will be blend with 2 subwoofer enclousures on each side, for now this is the frame with the power blocks behind them, I need to buy another ground block a more 4gauge cable. but I had to stop working on it the 99degrees outside was killing me.
Looks really nice man. By the way, what wheels are those? I'm looking for some for my Mazda3 and those look really nice (have to love that all the Mazdas use the same bolt pattern).
Here are some pictures of the midranges installed, I will take more pictures when I vacumm the inside of the car //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Do you have control??? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I installed the 5 amplifier gain remotes were the Traction Control switch used to be, I don't used it never so I just put it behind the remotes.
On the right side of the remotes I will put the 3 buttons for the AudioControl DXS, and the display for the DXS will go in the middle of the dash were the stock head unit lcd used to be.
PS: I need to clean my car but it's still under installation period //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif, I will clean it later.
Awesome install, and sweet ride. Doesn't the CX-7 have the turbo 2.3 in it?
Yeap, the best of both worlds turbo and space plus nice looking //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif:D:D:D:D The Blaupunkt amplifiers sound GREAT, they move my RS180 hard , with a very nice deep midbass. Midranges are powerfull and clear, and highs very detailed.
But I just bought a brand new 6ch JL amp and a 4ch JL amp (bridged for my subs) to reduce space in my trunk. I don't whant to sell the blaupunkts amps, they sound to nice, I might keep them for a while.
I also tested the crappy laptop sound card with my system and it sounded very good, so I think I won't be needing the JVC head unit.( I don't have where to put it also) Tomorrow 4th of July will be a busy day finishing everything.
This will be the new amps, I wanted the slash series but my budget was limited.
PS: YES I do change my mind very quickly. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
6 channel model
4 channel model
A little video of the laptop connected to the amps //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif. Sounds very CLEAR.
You tube *****, the audio is kinda distorted after converting.
I'm still working on some ground issues when the car is on
http://www.youtube.com/watch?v=Acp9s8i95yA
Kicker 46CSS654 CS Series 6-1/2" component speaker system chose these for the front chanel Kicker 46CSC654 CS Series 6-1/2" 2-way car speakers...
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
457
CRD
CRD
Orlando, FL
nitro_freak1
audiobaun
    May 19, 2024
    May 19, 2024
