Sguirrelfeather
So, like the title says, I've done some research, but now I think I'm more confused than ever. lol Since I can't have a sig yet, here's my setup:
2004 Ford Excursion (a LOT of space to fill with bass)
JVC KW-R910BT head unit
JBL GTO-5ez amp running 1 sub and front/rear door speakers
500W to sub @2 Ohm, 75W to speakers (RMS)
JBL GTO-3ez amp running another sub and the rear passenger speakers
2 x 10" JBL GTO1014D subs in sealed enclosure (1 box, 2 separate compartments, 1cuft each) between front seats
350W RMS subs...I knew they were below my amp's rating, but i got a deal so why not. lol
6 x JBL GTO 509C component speakers - 5 1/4 mid, 3/4 tweet using included x-overs
75W RMS
So, I figured I would eventually have to replace the subs because of their lower power rating (this was before I knew how to set gains to compensate for that, though that is currently being a pita). I've repaired the surrounds twice, and they are starting to tear again. Tax time is coming up, so I figured I would start looking for something which could handle the 500W RMS and still give me good SQ while providing SPL as well. A lot of people recommend DD, a lot say sundowner, and so on. Here's where I begin to stumble. DD does not list sensitivity, so how do we know if they'll deliver the volume in a properly built box? The sundowner I looked at had sensitivity down around 81dB. To me, this shows that it has more rigidity, and can therefore handle more power than what I currently have, but then does that not also mean I will need more than 500W RMS to get the same volume as what I get now? And I can't even figure out what some of these other brands are that you guys talk about. lol
I tried to see if it was possible that the local "high end" audio place had a clue. I knew it was a long shot. Yeah....all they could do was tell me about what they had in stock, and kept pushing speakers which would NOT handle the load, even though he assured me their max rating of 1200W meant it would handle my 500 RMS. asshats
So is there any help to be had here? Will I need to go with higher RMS on a sub like the Sundowner? Are DD's loud enough with the SQ even though they don't list sensitivity? Are there other brands I should seriously consider? If so, why?
And to make sure I have fulfilled all the requirements of what you will ask for (based off the sticky), here's the rest of the info:
two subs preferred...sealed, because even though it's a huge truck, I want to keep them between the front seats.
10" would be best, but I think I could fit 12's in there if need be.
I'd like to not spend more than 500 for the pair, but may be able to stretch it out to 650 or so.
Space available is 14" wide, 12" high, 30" long
I mainly listen to metal, hard rock, some odd stuff like Lady Gaga, Turn Down for What, etc...stuff which has a lot of bass.
I don't have preferred brands, but I will say I don't want something I'm going to regret, which is why I'm asking for help. lol
75W RMS
