Couple of questions......
johndoe1234
boxes are built to a subs specifications. prefabs are built to generic specifications that they feel will work well with any sub. manufactures usually give you the specs of their box, if you can find subs that will fit those specs well then there is a prefab box that will work good with those subs. but to get the most out of what you want, you should consider buying or building a custom made box built to the specs of your woofers
Just a note; All you guys wanting enclosure designed / built or what ever
I keep seeing all these air space or volume request with speaker size/ tuning frequencies and so-on
It is very important to know more information
like the type of vehicle and more
The environment (Vehicle) will seriously effect “ALL” these factors
An Experienced Subwoofer Enclosure Designer (not just builder)
Needs to account for All the variables
True available space
Locations and surroundings for new enclosure
Distance to the Listeners
The Acoustical Characteristics of the Environment (different vehicles and certain
locations inside of that vehicle will react differently
Power Demands
Audio Objective (Type of Music, Response and SPL Levels)
Cosmetics (Looks)
Cost (The Cost of a Custom Subwoofer Enclosure can go and be divided up in
many directions)
You can spend a lot of money on just Looks (Fiberglass, Paint, Vinyl, Plex, Neon,
ECT...)
You can spend a lot of money on Performance (SPL or Sound Quality)
It’s finding the right Balance for that particular Project
An Expensive Subwoofer and Amplifier dose Not Equal GOOD BASS
Straight cut MDF and a Box Program dose Not Equal GOOD BASS
Smaller and\or Fewer Subwoofers Done Right Will Out Perform More and\or Larger Subwoofers Done Wrong
Big and Expensive Subwoofers (W7, 9500, Power T) is Not Always More Bass
Big and Expensive Subwoofer Sound Bad in Cheap Boxes; Spend the money on the Enclosure not the Sub
Just a note; All you guys wanting enclosure designed / built or what everI keep seeing all these air space or volume request with speaker size/ tuning frequencies and so-on
Power Demands
Cosmetics (Looks)
many directions)
ECT...)
correct, and we always take most of those into consideration. but not everyone has the time or ability to figure out the correct tuning for that specific vehicle. somone in california building a box for a guy in new york isnt going to drive over there to figure out the proper tuning, imaging, placement of the box. he is just going to build it to the specs of the sub and what the customer wants. its the box that makes the sub sound good, but its the sub that makes the box. you cant just put any sub in any box.
johndoe1234
johndoe1234
Mesa, AZ
blackbonnie
