Couple of questions......
espguitarist91
yep
Ive got a couple of questions about my door speakers. I think im going to replace the stock 5 1/4" with either a coaxial or a 5 1/4" mid driver/woofer or whatever you want to call it. Well Im not looking for anything great, or good for that matter. I just want to add a little midbass upfront. I was wondering if anyone knows how deep of a speaker you can put in the door of a 1992 deville? If not, is theyre an average mounting depth that id be sure that would fit? Also, if i got a woofer, im guessing i would need a crossover, right? At what frequency? What would be the effects of running it full range, Stock speakers do it...... Im probably going to be ordering for partsexpress because theyre cheap, so that means either Dayton or Tang band basically. Also, what impedance should i get. Im not sure what the stocks are, but i guess i could check if noone knows.
Thanks
Ive got a couple of questions about my door speakers. I think im going to replace the stock 5 1/4" with either a coaxial or a 5 1/4" mid driver/woofer or whatever you want to call it. Well Im not looking for anything great, or good for that matter. I just want to add a little midbass upfront. I was wondering if anyone knows how deep of a speaker you can put in the door of a 2992 deville? If not, is theyre an average mounting depth that id be sure that would fit? Also, if i got a woofer, im guessing i would need a crossover, right? At what frequency? What would be the effects of running it full range, Stock speakers do it...... Im probably going to be ordering for partsexpress because theyre cheap, so that means either Dayton or Tang band basically. Also, what impedance should i get. Im not sure what the stocks are, but i guess i could check if noone knows. Thanks
2992? LOL
average? 2.5"
unmount the speaker and see for urself to be 100% sure
get a fullrange speaker, u wont need crossover, just highpass them at ur taste on ur Head unit....
impendance, 4ohm is preferable
espguitarist91
yep
espguitarist91
bloomingdale IL
espguitarist91
