With all due respect, I tend to disagree with this answer ^^^. This can easily be done without strapping the amps and without damaging the sub or the amps. I've been running a JL DVC sub like this for years in my daily driver. I power each VC with two separate bridged outputs of a spare 4-ch amp I had on-hand.
Just make sure you feed each amp channel the exact same signal, make sure you wire the VCs to the same correct polarity, and try to match the gains as closely as possible.
And, yes, each VC should handle half of the total rated RMS power of the sub, but to be safe I try not to push it to full power when running this configuration.
