Ingleside
then do what i told you to do already.Ingle, you PM'd me and I tried to PM you back but your box is full....
The factory amp is pretty easy to access, it is behind the glove comparment.
run wires from your head unit to your factory amp. dont hook thoes to the amp.. but the wires that go from the amp to the speakers. this way you use the factory wires running to each door instead of having to run new wires to each door.
at the same spot, the factory amp is where you check to see how many ohms the speakers are. disconnect and check the wires one by one off the amp and check the ohm rating. thats how you find out exactly what the final impedance is for your door speakers.
