Supergumby5000
Project: F350 begins...
//content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gifIf you're going with a mono block then you have to look at it as all 3 being wired together, even if the amp appears to have what looks like 2 channel inputs. It doesn't, many mono's just give you 2 speaker inputs for ease of use, but internally the amp 'bridges' those two inputs into one.
So in your config above almost all of the power would be going to the 2 ohm sub and hardly any to your dual 4s. This is because the 2 2 ohm VCs will have less resistance than your 4 ohm VC (it doesn't matter how you wire it, they'll always be 4 ohm VCs) and power 'gravitates' to the point of lease resistance.
If you absolutely need to mix ohms, then you're better off going with a 2 channel amp. This way 1 channel can power the 2 4 ohm and 1 channel can power your 1 2 ohm. This will prevent all the power from going to your 2 ohm sub.
another, more simple way to look at it is this. Your splitting the power between TWO subs wired into ONE configuration that matches the ONE other sub configuration.
As drawn in the picture, the power will be split TWO ways: 1)towards the pair of subs and 2) towards the separate sub. How is the amplifier going ot know to send more signal to the two D4's rather than the D2? its not. The signal will be split evenly regardless.
