westman995
Right now i have two kicker cvr 12's. They are dual 4 ohm. I was thinking of adding a third.. Right now my shit works bets on a 2 channel amp doing 2 ohms to each sub. (but i dont have an amp right now so it dont matter) I was thinking of adding the 3rd and making it a dual 2 ohm. And wire it all upto one Mono amp. I assume it would be safe as long as i get the ohms right for the amp cuz the voice coil config. is only to give you wiring options right?
So basically i want to wire up two dual 4 ohm subs and make it a final output of 4 ohms, THEN i want to wire up the dual 2 ohm sub making it another 4 ohm output, THEN I want to wire those together and get a final output of 2 ohms. Will this work?
Sorry if that was confusing i tried my best to explain haha.. Im thinking it will be 2 ohms final output but i dont really know for sure. Any help is appreciated.. Thanks in advance..
