cotton type material backing on vinyl?
No you leave it on. There are many types of vinyl. The stuff with more cotton stuff on the back is the nicer stuff and a lot easier to work with. I would try not to use too much heat on that stuff might make a bad looking spot on the vinyl. If you have to use heat put it on the back side of the vinyl and feel the front with the back of your hand when it starts to get a little warm that's all you will need. Then you work with it.
I am using the vinyl to match my interior, i dont think the laminate will match
actually the textured black looks like it would match, but not sure how well it would take to curves of a fiberglass enclosure??
I prefer my vinyl with no backing at all. It makes for a tighter, cleaner fit around 90 degree corners and such. Also better for embossing. That cotton batting doesn't stretch evenly under the vinyl and you end up with a wavy mess. Just my 2 cents.
The vinyl with the cotton batting is good for covering up crappy fiberglass work though. Hides a lot of the imperfections.
there are alot of different kinds of vinyl that stretch in alot of different ways.
take a sample of the vinyl and see which way has the most stretch to it so you will know which way to orient it when you put it on to go around curves and edges to get the best fit.
and leave the backing on it
PolishDude
PolishDude
Tampa, Fl
h17250x
