cost to build a box?
ehh well one of my boxes if it takes 1 sheet with carpet will cost me around 100 bucks
but i use TruPan Ultralite wich is around 50 a sheet and carpet is usualy around 20-25 with glue then u got screws and glue... i just use wood glue in the seams... if u get the cuts right u dont need anything realy
but a simple box with MDF can be done for around 50 bucks
Where are you guys finding wood glue for $3-4??? I pay around $9 for Titebond II.
Also add in black paint for the port, $20+ for 2 rolls of carpet, and $10+ for the spray glue. MDF is about $26 out the door at my HD. Also need some 10g wire and terminals.
It's not really as cheap as some guys make it out to be, but still much cheaper to do it yourself if you have the tools or can borrow them...
If you get all of your dimensions before you go to home depot or lowes you can just ask them to cut all of the sides of the box. Thats what I did. It took about 5 minutes and everything came out nice and straight and probably saved me a good hour or so.
You can have Home Depot do your cuts, just have them cut everything 1/2" long or so. Then, just trim everything up to true specs. i just have them cut the sheet in half, as i don't have a truck. I have to put the MDF on top of the car usually.
Home Depot has a sign by the saw that says "No project cuts", but slip the guy a tip, and you would be amazed how well they can do project cuts.
To summarize:
1 sheet 3/4" MDF: ~$25
1 5/8" screws (I use drywall, they seem to work well) - $5
Bottle of Titebond III - $5-10
Tape measure
Table saw
Jig saw or Router
Good drill bit and countersink
~$50 for a MDF box.....plus carpet and adhesive if you are going that route.
Good luck. I enjoyed building my first.
GabeC
GabeC
ColaTown, SC
mlstrass
