Copper or Aluminum?
As far as my experience the only up sides for Aluminum is being lighter and in AQ's application the spiders are sandwiched instead of having a spacer in between them.( Hand made )
Both accept retarded amounts of power and I found the copper coils to withstand daily at high volume better than aluminum.
Hope that helps.
Sorry about that ...I was talking about coils.I was looking at a few different 15's.I think it was the Audio Q HDC 315.I did not know the difference between the 2 materials.OR if there really was a difference...??
thor how much power are you putting to each of those 10s....i mean i'm thinkin if you got dual 1's they at around 1 ohm each...(with box rise)
I have my 10's on 2 5k's strapped at 2ohm ( 1 ohm per ). In the past I ran them on 1 5k at .5ohm and had no issues what so ever. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Rob is correct. the alu are lighter which is louder but the coppers are better daily on music. the coppers handle the heat better.
cliff notes
burping=alu coil
music=copper coil
My aluminum hdcs handle the power much better than the copper coils could even dream of on daily usage. I will never buy copper coils agian for my hdc...
Zinc also conducts fairly well. I use zinc nuts and bolts on the terminal cups I build into my boxes.
777
Link to antenna. I'm guessing the copper foil should be connected to glass, not metal, but lets see the antenna. Did it come with instructions?
Not friends at all. I see are you are another JP hater with zero proof of anything. He wasn't even driving that truck. Haters will always hate. He...
16
tenbux1970
Amateur Gynocologist
tenbux1970
Mendota,IL
Towncar
    May 24, 2024
    May 23, 2024
