Considering this system....any thoughts?
Marktect
I'm building a 1946 Chevy pickup street rod, complete frame-off resto mod, and am considering the following set up for a full active system.
Head Unit: Mini iPad with Pure i20 for digital out
Signal Processor: Audison Bit 10 D (Also considering Bit One).
Speakers:
Front (Audison)
Voce AV 1.1
Voce AV 3.0
Voce AV 6.5
Rear. (Audison)
Voce AV X6.5
Sub (JL)
13TW5v2-2 (I have very limited space, and have to use shallow mounts)
Amps (Audison)
AV Quattro - (front mid and tweets)
AV 5.1 K. (front mid, rear coax and subs (mono)
Any thoughts or suggestions would be appretiated
That's one sick setup! I would recommend going 3 way active with the bit one with optical in from the pure, I would personally ditch the rear speakers and use the money to get a bit one and optical.
Capil, thanks for the suggestion, I am definitly going with the digital optical from the Pure, the upgrade to the Bit One is a pretty good chunk of change, I'll have to look into it further.
Because of the size limitation I would have to go with a much smaller Dayton Sub...probably in the 8" range. That would still be a better option?
Don't go from a 13tw5 to 8s. This is crazy talk. Your list looks crazy expensive but the JLs fit right in.
you know when me and my pop's did his '36 willeys we were strapped for space we welded boxes under the seats, 2 10w3 nobody thought it would work, but sounded great....
In my 46, the gas tank was located under the seats, so we are putting the Amps there and relocating the tank to under the bed, as is, it is barely enough room for the amps, we were able to make an angled box behind the seats for the subs that has just enough area to support th JL's
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
223
630
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
16
Marktect
Marktect
Lancaster, NY
Marktect
