Considering this system....any thoughts?
Marktect
I'm building a 1946 Chevy pickup street rod, complete frame-off resto mod, and am considering the following set up for a full active system.
Head Unit: Mini iPad with Pure i20 for digital out
Signal Processor: Audison Bit 10 D (Also considering Bit One).
Speakers:
Front (Audison)
Voce AV 1.1
Voce AV 3.0
Voce AV 6.5
Rear. (Audison)
Voce AV X6.5
Sub (JL)
13TW5v2-2 (I have very limited space, and have to use shallow mounts)
Amps (Audison)
AV Quattro - (front mid and tweets)
AV 5.1 K. (front mid, rear coax and subs (mono)
Any thoughts or suggestions would be appretiated
That's one sick setup! I would recommend going 3 way active with the bit one with optical in from the pure, I would personally ditch the rear speakers and use the money to get a bit one and optical.
Capil, thanks for the suggestion, I am definitly going with the digital optical from the Pure, the upgrade to the Bit One is a pretty good chunk of change, I'll have to look into it further.
Because of the size limitation I would have to go with a much smaller Dayton Sub...probably in the 8" range. That would still be a better option?
Don't go from a 13tw5 to 8s. This is crazy talk. Your list looks crazy expensive but the JLs fit right in.
In my 46, the gas tank was located under the seats, so we are putting the Amps there and relocating the tank to under the bed, as is, it is barely enough room for the amps, we were able to make an angled box behind the seats for the subs that has just enough area to support th JL's
Marktect
Marktect
Lancaster, NY
Marktect
