Considering going active..
mr Tibbs
and using my 860mp as a active x-over. Anyone else doing this? Also, how hard is it to tweak the system? I'm a little intimidated, is it that hard or is it easy enough that even an amature can handle it?//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Quite honestly; it's not something for an amature to attempt IMHO.
It sounds easy. But in reality, there is a lot you need to know and understand in order to adjust everything for optimal performance
So, that's it? Anyone else have an opinion on this? I understand it's not going to be easy, but I thought it might still be fun to try.
I'm in the process of going active. It might be fun at first, but it takes a long time to set it up and to tune it. You have to know what you're doing at least a little bit. My system sounds a little better than it did before, so it might be worth it.
All I really need is an amp for the tweets. I can pick one up for fairly cheap, so I'm going to go for it. I hope your all ready for a lot of questions!//content.invisioncic.com/y282845/emoticons/hide.gif.2d479cfd917eedfe201353b91522ceab.gif
Head unit: Pioneer Premier 860mp
Front Stage: RE RE comps with CDT 1" silk tweets
Rear Fill: 5 1/4" infinity coax's ( If I go active these will be cut off)
Sub: RE SE 12" in a custom ABC box( man I love this sub!)
Amps: MTX Thunder 500D (sub), MTX Thunder 302 (comps)
and all of the wiring and stuff.
I'm looking to pick up a MTX Thunder 152 to compliment the other two amps to run the tweets active. Really I'm pretty much set if I get the 152. I know wiring it up will be a breeze, I'm just concerned with the x-over points and the slopes and stuff. I guess if I absolutley hate it I can always go back to passive, but I'm kinda looking forward to trying out different set ups with different drivers and tweets and the such.
mr Tibbs
mr Tibbs
Utah
alphakenny1
BP1Fanatic
BP1Fanatic
