Connecting power wire to battery...
deaf16
Hey everyone Im running 4 gauge power wire in my Tahoe and when I was finishing up today Unfortunately the hole on the Rockford 4 gauge crimp ring is a little too small to fit over the screw of my positive battery terminal...what should I do, this is the first time I have had one not fit...
dam when I went searching for them I couldnt find them in my area, so all i did was take some cutters and cut one part in the center and spread it wider on each side, then just screwed the sht down. Its been like that for over one year and not a problem yet.
or take the end of the connecter and hold it with either vise grips or if you have a strong hand some pliers..get a drill with a bit a little bigger then the hole....lay it on the ground and drill into it...drill till the proper circumfrence is acheived...ouch
deaf16
deaf16
Florida
Sleeklsc
