Connecting Amps
na_rsx
Incriminator Audio FTW
I got a question to ask all the professionals out there. When connecting the power and ground to the amps, do you really need to use a spade terminal. Or can you just connect the wire and tape it up with electrical tape. To prevent anything from being loose. When i redo my amps, i am not sure what to use. What will give me maximum security, and if i need spade terminals, which ones are good.
Thanks,
Juan
If you can use spade use them....Nothing says you will have problems if you do or dont. make sure no wires touch, even one little strand!
yeah, i figured that much. thats what after i screw it down, i will use electrical tape to secure everything. i just feel the amp will get a better connection without the spade.
thanks for the replies.
depending on the terminals on the amp.
if its the one where its better to use spade terminal just use one.
Well 1 amp is a Elemental Designs Nine.2x, but when i try to put a 4 gauge spade terminal, its a ***** to get in. And which spade terminals are good, that provide a clean crimp?
None of the eD amps use spade terminal connections. They are all bare wire connections. Undo the set-screw. Strip about a 1/2" of insulation off the end of the wire. Slide the wire into the terminal as far as it will go and tighten the set screw. Make sure that you don't have any stray strands of wire sticking out.
gotcha, will do. thanks. i have a pioneer amp, which is temporary until i save up for the nine.2.
na_rsx
na_rsx
With Jessica Biel
na_rsx
