Cone Area vs Xmax: For a Daily Setup
CJL
oZone
I know xmax has little to no effect in a SPL application but, lets say a 10" sub has 25mm xmax and a 12" sub has 12.5mm xmax, which should get louder in a daily application if both subs has similar specs?
For daily, especially in a sealed alignment, the sub with higher xmax does have the advantage in terms of SPL, especially down deep. "There's no replacement for displacement" //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I was thinking about the same thing today. And was wondering about the relationship between Sd (surface area of the woofer) and the xmax. Was surprised when I actually looked at the Sd of a few different woofers of the same size only to find out they were different.
Both are equally important. A woofers SPL ability is just that, it's ablility to cause pressure variations, the more air you move the better. Whether its 1 large cone moving only a little bit or a cone of 1/2 the size moving 2x as far is of no consequence. vd=xmax*sd
The 10 is going to get louder, it will probably just require more power to do so.
The claim that xmax doesnt matter at all for SPL applications is also false. It DOES matter, as it does with any application, but it isnt the most important factor.
Now bear in mind, when we are talking LINEAR output, regardless of enclosure, that is determined by displacement (Sd x xmax)
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
618
Buck, great idea. I did that tonight, and it actually didn't wheeze like a fat guy trying to run a marathon. I am going to put two windows that...
19
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
878
dc audio lvl 3 lvl 4 soft parts recone kit they kot hard af at 27 hz
CJL
CJL
oZone
Toxic Tuan
    May 18, 2024
    May 18, 2024
