Comps dont work... wiring?
tapout383
Just boughta Zone.
i installed my compents today and it seems as though i may have it hooked up wrong could it be my grounding or wiring....they play very low when i turn the head unti all the way up but you can barely here it...could this be a grounding issue?
i though someone would atleast attempt to help //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i turned it up that cant be it...im assuming and hoping its because im not using the correct wire and grounding it right...im using like 14 or 16 ga twisted speaker wire for my power and ground...i know thats dumb but i was hoping i could hear them tonight and not have to wait to get wiring kit
well i upgraded to 8ga wire...and still the same as it was...if you turn the level knob up to high it will go into protect it and i still have to max the head unit to even get a little sound out of it
ok i found out what the problem was but i also fried my tweet the mother ****er started smoking then melted anyone know what couldve done that
What type of specs does your amp have, if the ground was an issue it would cut off at higher levels but maybe your amp ain't strong enough
nah its 125rms at 4 ohm it was strong enough but now it has like a echo in the music like the person is singing under water...i need to do tuning but i got to find another tweeter now...i think it may be to much for the tweeter or i had it crossed wrong or something i know the thing straight melted
something is deff not right...the amp as started to smell and is starting to smoke a little bit i have cut it off untill i fig out wtf is wrong
tapout383
Just boughta Zone.
tapout383
Virginia
tapout383
