headunit istall help
dumple
What's in your trunk?
Might be in the wrong section, buuut.
I have a saturn ion redline and a eclipse avn 7000, my car has the advanced audio system( built in amp for front and rear speakers.) Im tryin to install the headunit with the metra harness for my car but heres the problems.
1. The deck has 12v constant when the key is out of the ignition and the door is open *shouldnt have power/turn on*
2. no sound out of the speakers ugh
if anyone has any insight that would be great
Do you have the correct 12v hooked up, there should be a 12v constant for your hu's radio station/settings memory and a 12v for the on/off
Also how does the hu connect to the amp? via RCA or speaker level inputs?
its a factory amplifier thus it connects via neither i suppose. it has the exact same harness as the radio its self(stock radio that is
test the constant and accesory wires. also since you have the factory amp you may need to hook up the remote wire to turn it on.
u sure you got the right harness for the amplified system? because they're usually different from the non-amplified systems.
dumple
dumple
Philly
Atimm693
michigan born
    May 14, 2026
michigan born
    May 14, 2026
