Completing a system
NCspecV81
Okay guys I'm looking for the best deals I can get. Fiancee's orders. =o( Anyways I already have a DEH-80PRS and just got a Zed Leviathan III from vortex audio. I haven't been into the car audio seen for quite some time so needing some recommendations on speakers and maybe a sub. Looking for 1 maybe 2 subs max that can take advantage of the amp and some front components to do the same.
Car in question is a 2003 sentra with non-rockford setup but does have the tweeters on the a-pillars. I think the doors are 6.5 inch but I believe mounting depth could be a problem with larger components.
I could give you a nice discount on a display model set of CDT Audio ES-6MOPro Gold components. They would require at minimum a 1/2" spacer for the mids. The tweeters have a very small housing compared to other 1" tweeters, so that might make them easier to fit in the stock tweeter locations. These are top of the line components that would sound amazing with the power from the Leviathan III.
Components are decided. Still need sub. Looking for something JL W7ish in quality and capability. Will have channels 5 and 6 and possibly 3 and 4 for sub use. I believe the channels bridged are 600x2@4ohms. If I read the manual correctly as long as I'm feeding the same single into the amp I should be able to use both 3 and 4, and 5 and 6 as sub channels. Correct me if I'm wrong. But still looking and looking to buy. Thanks in advance!
Not an exact budget but I don't want cheap. I want something that will sound extremely good. Especially in the lower frequencies. I don't listen to much bassy type rap music but I do want capabilities. Fiancee will be mainly listening to pop christian type music. Like jars of clay, bruno mars, etc.
NCspecV81
NCspecV81
North Carolina
mylows10
