Combining speaker outputs on HU amp?
UCbizerkeley
Quick question - I have an Alpine 9833 head unit (oldie but goodie ). I want to use the HU's amp to power solely my real coaxial speakers, as they are just rear fill. HU is wired to battery naturally. The amp does 26rms x 4 channels. Am I able bridge those channels to send ~50 RMS to the rear speakers (2 channels)? Is it as simple as wiring the front negatives with the rear negatives, and the front positives with the rear positives? Or can I not do that at all?
Thanks in advance!
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
not that i know of.. most headunits are 4ohm min load.. that would put 2 ohms on each channel.. check its load min
I am no expert, but wouldn't you only lower the ohm load if you wired two sets of speakers in parallel? This is only going to one set...which might double the ohm load? I have no idea actually
seen it done in other peoples rides i have worked on/ fixed for them i do alot of installs when im home for people around town .. I would say it wont work but it always worked for them i always correct it and they dont notice a difference so .. to your question will it work yes will is send double the power prolly not .. will you notice an increase NO .. will you evetually fry your amp YES ..
I wouldn't risk a nice HU like that.
Bridging isn't that easy - in an amp it involves inverting one of the two channels. One channel drives the speaker for half the wave, the other channel drives it for the other half.
With an HU what you end up doing is having one channel driving the other. The fact that it doesn't automatically result in a fried HU amp is surprising to me.
Besides - 20+w is plenty for rear fill.
I run 180x2 in front and 15x2 for rear fill.
If you bridge a HU amp, you are a fvcking reeeetard af the worst sort. Give up car audio, NOW
Ok for sure, good point. I just put everything outside my house with a FREE sign on it
Thanks for the kind words, I will not be bridging my head unit. Glad to hear a measly 26x2 will work for rear fill, I don't really want those speakers to be heard anyways lol (Alpine Type-S FTL).
Thanks everyone! Case closed.
UCbizerkeley
UCbizerkeley
berkeley
UCbizerkeley
