Clarion DXZ945mp Help
  • 4
Petey_W
I bought this used, and did the install myself after finding the wiring schematic online. The problem that I am having is that there is NO audio coming out. I can put a CD in and see the EQ on the display. The only thing I can think of is that the unit has a wire for cell phone audio mute. It is not connected anywhere right now. Could this be the problem? If so, what do I do with it, tie it HIGH or low.
Before I bought the stereo, it was working fine, be it was being used with amps, via the RCA jacks. I am just using the 4 sets of speaker wires.
Any help I could get would be greatly appreciated!
~Petey
Not really understanding exactly how you connected the amp?? I had an issue w a brand new HU, and trouble shooted for like 2hrs, and gave up during the night, by morning..I reset the HU that I couldnt see the night before, and was not in the info booklet for the HU??Go figure..It worked as it should after resetting??Might try that first, then if not, explain to detail what amp/model you have, and HU, and exactly how you connected the two together, and maybe some one here, can help, as well as me?Just a bit vague on the connecting the two together, and models/amp/ stereo.Try resetting first, see if that helps, if not let us know??:,Unplug the RCAs also??If you wired through the high level input, you dont need to use rca???D
I am not using an amp at all. The only thing I am using is the 4 sets of speaker wires. The guy that had the unit before me WAS using the amps though. Is there something in the software of the Clarion DXZ9454MP that tells it what outputs to use? I have tried resetting via the reset button behind the face plate of the HU. No luck, same problem. Is there another HARD reset that I am missing?
The internal amp is fried. Buy yourself a 4 channel amp and use that instead and call it a day. lol
Looks similar to this: https://www.sonicelectronix.com/item-17681-Clarion-CX609.html I'd call Sonic Electronics and see if they have what you...
Thats its manual fore using, not Tecnical.expaining , have pinted out service manual., and the cable i think was fore swc,its made fore satelite...
I dont think anyone can answer that question of if a BTooth adapter will sound as good as a CD? Only one would know by actually using the same...
954
I would recommend to get on F.Book @ Old School Stereo and run a Want To Buy thread there. Im sure someone is hoarding one, maybe even a BNIB one...
I know what you mean ....its a pain going in all those menus ...i think kinda look at these new decks like old school trunk mount processors...
Petey_W
Petey_W
United States
Petey_W
    May 16, 2024
    May 16, 2024
