Circuit Breakers vs. Inline Fuses
evilsaint
Simple question. Is it safe to use a circuit breaker in place of an inline fuse next to the battery? If so, would you use a breaker of the same amperage, or higher/lower? It'd be a lot easier and cheaper than replacing popped fuses, so i figured it would make sense.
yeah, what he said, but, make sure you get the fast type, not the slow type. im so cheap, i took one of those outlet strips, and cracked it open and took the 15amp circuit breaker out of that. i also ripped open an old power wheels battery and took the breaker out of that. hahahah
Originally posted by lamontjersey yeah, what he said, but, make sure you get the fast type, not the slow type. im so cheap, i took one of those outlet strips, and cracked it open and took the 15amp circuit breaker out of that. i also ripped open an old power wheels battery and took the breaker out of that. hahahah
you mean you took a 15 amp breaker from a 110 volt AC outlet strips? im not sure thats a good idea at all.
and look at this site and find the section about circuit breakers. hes totally against them and gives the reasons why....even though i use a 150 amp breaker for my sub amp...-scott
look at what site?
yes , i took it out of a 110 v strip, i just use it for short circuit protection, i know what you are going to say, ....15amps at 110 volts dont mean 15amps at 12v, but my s ystem has one sub and i havent actually tested its actual trap current yet, i will be testing it soon.. i havent actually installed it yet, but i did rip the one out of the power wheel battery and that should trip at about 20amps.. i got a 100watt amp
It's perfectly acceptable to use a higher voltage rated fuse or circuitbreaker. The voltage rating has to do with the distance the contacts will separate when the device trips or blows. You can use 115V devices on 12 volts, but not the other way around. Most car fuses are actually rated 32 volts.
Good quality UL listed circuitbreakers will always fail open. The worst you could expect would be nuisance tripping.
evilsaint
evilsaint
NW Chicago 'Burbs
MikeofTulsa
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
