factory system
stevert_2003
if you want to hook up an amp with the best signal possible i would recommend getting a speaker to rca converter. I know that Scoche makes them, you can get these very easily at your local wal-mart for maybe 15 - 20 dollars. i'll describe them. you usually see speaker wires that go into the product the theres a box with a built in x-over then there are speaker outs so that you can hook your speakers back up to the head unit, plus there are rca outputs that give a clean and clear signal that you can put into your amp. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by stevert_2003 if you want to hook up an amp with the best signal possible i would recommend getting a speaker to rca converter. I know that Scoche makes them, you can get these very easily at your local wal-mart for maybe 15 - 20 dollars. i'll describe them. you usually see speaker wires that go into the product the theres a box with a built in x-over then there are speaker outs so that you can hook your speakers back up to the head unit, plus there are rca outputs that give a clean and clear signal that you can put into your amp. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
this is true
Ummm....//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif :crazy: //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
stevert_2003
stevert_2003
Pierre SD,
ftgu
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
