choosing fmods?
Are you trying to bandpass your mids or just cut out some of the lows or highs? As far as how they work it is very simple. They plug inline with the rca cables feeding the amp you are using for the mids and that's it. They are just tiny crossovers built into an rca plug.
I want to get a pair of fmods to use with soundqubed pa mids so I can go active with my amp but I'm not sure what to look at and I'm not sure how they work. Would I get the high pass or low pass fmods and what hz do I get for them? And can someone explain how they work?
FMOD Crossover Pair 100 Hz High Pass | 266-274
u want these 100htz hpf...they are simple plug and play inline crossovers..u plug them into the amp where the mids will be then plug in the rca to them then open up the hpf all the way and the fmod will automatically set the crossover to 100 htz
---------- Post added at 11:09 PM ---------- Previous post was at 11:09 PM ----------
I cross my aq pa mids at 100 works great
Justin braaapp
Justin braaapp
Torrance CA
NSTALN
michigan born
    May 14, 2026
michigan born
    May 14, 2026
