Choose an Amp
  • Thread starter Unregistered
  • Start date
  • Replies 4
  • Views 771
  • 2
U
Unregistered
Guest
Say I hv 2 x 12" Rockford HX2 sub 500w rms each(dual 4ohm vc)
But I'm thinking get a RF 1000.2 or two RF500.1
cuz both r giving 500w rms 2ohms....but 500.1 this Mono amp is class BD...will it more suitable for subwoofer???
500.1 is 500w @2Ohms
I use two 500.1 to power 2 x 12"...is it alright>?
For that amount of power class D would be most practical.
The rf class D's won't work well in your case b/c that amp wants a 2 ohm total load. With a pair of dual 4's you'll have either a 4 ohm or 1ohm load.
The 1000.2 would be great b/c it is 500x2 at 2 ohms, or 1000x1 @ 4 ohms mono. Each of which can be attained with 2 dvc 4's. However you'd be drawing quite a bit more current than a comparable class D.
The all too common jbl 1200.1 would be perfect, or for that matter any class d that's around 1000 rms at 1 ohm. There's a bunch.
Yes audiolife, I'm matching impedances again (Oh No!!) //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
Complete novice at this so that is why I am here. Looking for guidance on what type of speakers I should be looking at getting to replace the...
I am upgrading standard door & dash speakers in a VW T5 camper (2005) using a plug and play upgrade bundle, continuing with the two-way setup...
Sundown for sure. I've never been impressed by the Avatar. I would also look at a DC Level 4.
664
Incriminator Audio makes so real solid amplifiers as well.
14
This would be a decent amplifier to run on what you have. I would spend a little more and get the 460.4 if you can swing the extra funds. Ive...
Guest
n2audio
    May 12, 2024
Brendon Jenness
    May 11, 2024
