Does anyone know how and or where i can run the power cord from the the amp in a 2001 tahoe? with either a photo, instructions or a video please?
What setup do you have ?hey one more thing. when i turn the radio the woofer cuts off.. what can that be?
Do you have a pic of this ?Yes driver side top of fire wall there's a hole. I got 7 runs I wire through it
I can take a pic tomorrow morningWhat setup do you have ?
---------- Post added at 07:23 PM ---------- Previous post was at 07:23 PM ----------
sounds good...i was just curious about the area ...i know a lot of ford trucks have a big firewall grommet thats easy to run wires through...i thought i remembered on chevys being tricky and having to remove the body brace...ive cut holes through the big wire grommet drivers side to the sides of the factory wires and never had problems though i dont like doing that but i figured its only big enough for a single 4 gaI can take a pic tomorrow morning
Im almost always up...Id need to know if its a dual 4 or dual 2 subwoofer ...If its a dual two wired to a 1 ohm load most likely its putting your amp into protect...I have several mono Alpine amps and all are only 2 ohm stable...so they would need a dual 4 voice coil with a single subi can have pics 2morrow morning. if your up now i can doit now but ill doit soon as i wake up.. but its one 12 Alpine with a mono amp also Alphine
