Check my design please
Well, what else do you need?
5.4675 cubes gross, 60in^2 port, tuned to 33hz, 30.5 in port length. Internal dimensions are 30 x 21 x 15.
if you drew the enclosure to those values. then it should sound good.
But it will actually help to add the dimensions to the drawing to double check that the enclosure was done exactly to the parameters provided.
calculating the port displacement as if the port was straight will not equal the same displacement when you bend it.
you have to take that into consideration when calculating the internal volume of the enclosure.
THXdts
THXdts
Maryland
THXdts
Mike Mccabe
