subzero
Suppose I put four 40 amp fuses in instead of the four 30 amp fuses, what do you think?
it will create smoke inside the amp.Suppose I put four 40 amp fuses in instead of the four 30 amp fuses, what do you think?
Putting in bigger fuses doesn't mean your going to gain anything. You fuse the amp for protection, so why change them.I am not. I was just curiose to see what CA.com thought about this.
actually I was trying to figure the wattage in relations to the fuse rating and voltage drops. I dont intend to change my fuses.Putting in bigger fuses doesn't mean your going to gain anything. You fuse the amp for protection, so why change them.
There wouldn't be any point if it has never blown the 30 amp fuses. The amp can only draw so much current, if you want more power out of the amp you have to upgrade some internal components before you should change the fuses.actually I was trying to figure the wattage in relations to the fuse rating and voltage drops. I dont intend to change my fuses.
