Center Channel
  • 2
00navein
19
Bahrain
Centre Channel
Hi All,
I have a small issue with my center channel.
To begin with... i have 2016 Tucson and a win-version aftermarket Chinese heat-unit and it had a 5.1 channel RCA out, which i had connected to PXA H800 and Pioneer GMD 8604 (4 CHANNEL) for my front and back door speakers, Pioneer GMD 8601 for my Sub and Alpine SBS 0715 (amp and speaker set) for my center channel.
I used to play original movie dvds in my unit and could hear the dialog only from my centre channel when i used to enable the 5.1 out on my DVD. Also i have original Dolby test files and that too give me separations on each speaker.
But now the issue is I have installed a new Android 6.1 HD Chinese head unit but it has only 4.1 channel out and now that is the issue, my center channel does not work now.
I changed the PXA input settings to "4 channel & 2 channel" then it started working but now i can hear the dialog from all the speakers Nd also from the center channel.
How do i get the center channel working like before. Can somebody please help.
Thank you in advance
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
278
Audio Control ESP 3 is the way to go ..if your wanting to do a quality center channel setup ...
985
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
372
Well I ordered an oscope. Should be here today. And this beautiful beast showed up today. I’m gonna have to redo my battery and ground terminals...
36
6K
00navein
00navein
Bahrain
LosIsATool
    May 12, 2024
Brendon Jenness
    May 11, 2024
