cd wont play when car is on
wwwwhhhhhaaaassssssuuuuuuppppppp peoples. i got a clarion xdz616 that i install im my civic. problem is, the cd wont play when the car is running. when the car is off tho, the cd plays. everything works when the car is off, and the radio also works when the car is on. just that the cd wont play.any help would greatly appreciated.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
could u give us a little mroe info???kinda general...does it only work when the car is turned off do you have to reset all the memory stuff each time, anything else u can give us will help...thanks
There is a great repair place in atlanta called high-end car audio repair center their address is 1919 metropolitan ave atlanta Ga. 30315 they have very fast and precise service i highly recommend them. their # is 404-763-2005 or 770-473-6556
AUDIOPHILE4LIFE
ps their prices are great !!! and shipping and handling ups is cheap
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
3K
That's the dd1 The dd1+ has only 4 tracks. I have the dd1+ , just got home. I think the dd1 has all those other tracks. Diff tool. So it says...
9
Id remove it at this point and bench test it on 12v
6
jbarreras
jbarreras
moreno valley,ca
chris229
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
