cd player working with no sound.
corto
i have a pionner deh-07 the face plate doesent come off its older its like a 03.
i hooked it up in my girlfriends car and it turned on just fine with no sound. The radio or cd player has not even no static comming out of the speakers. I have no remote antenna only from the wiring harness not the cd player. Is there a way i can bypass this. Ive had this cd player working on 1 speaker hooked up on a battery charger. any ideas?
get a aftermarket wiring harness to wire the pioneer into or you could just go through and re check all your wires. also check your fuses one blown fuse can **** up a whole ride's system.
Oh alright man , id say next go through check all of your wires on the back of the Hu wiggle em around make sure there taped up or using something to make sure connections are tight , check ALL fuses including one on the HU if there is on idk if there is on the old ones or not i cant remember but try any of those.
Ok, you said that only one speaker is working. I'm assuming that before you installed the pioneer the music was coming out on all four speakers. If it was working before the installation and the pioneer is receiving power than it could be only a couple of things. It could be that the speaker wires are not connected correctly or it just might be the receiver itself. Meaning that the pionner has 3 bad channels. In that case send it to pioneer.
corto
corto
Flint, Michigan, United States
corto
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
