MultiDisc CD Player
Kenwood Kdc-c515fm 10 Disc Cd Changer With Controller, Remote, Disc Tray, Cables
Thank You!
That is a lot of wires!! is install as complicated as I think it will be?
The complication of the install totally depends on how mechanically inclined you are. For even a weekend installer, this is an extremely simple install. For someone who has problems with basic mechanics, then this might be a bit harder. It's very important to make sure you don't pinch any wires and/or drill threw stuff that shouldn't be drilled threw. I believe a shop would install it for less than $100.
Years ago, I had a multiple disc cd changer that worked by tuning my radio to a certain frequency. It had an attached remote control. Worked fine for me. I would contact Crutchfield or do a Google search to see if they are still available.
Those were called FM-modulated CD changers. Those were HUGE popular back in the 90's and early 2000's. We installed those all the time. That is what is being recommended for the OP.
recommendations?
If you're dead set on a CD changer, I'd recommend searching for a used Alpine Ai-Net headunit and 6 or 12 disc changer to go along with it. Headunit models that start with CDA, CVA, or IVA will control CHA-624, 604 or 1214 changers.
Getting a single or double DIN radio in your 2010 Tuscon shouldn't be a problem.
Best of luck enjoying your Broadway shows.
recommendations?
Wiring diagrams for old Alpine gear is still available on their website.
RooWalk
CarAudio.com Newbie
RooWalk
Coweta, ok
Mr12voltwires
randy hagan
    Jul 15, 2026
