CD Burning Problem?
dleccord
okay so i used the "drag and drop" method via the blank disc window. from their i go to file and click write these files to cd. after that i burn the disc using audio and then i did data for another cd. (this goes for 1kz tones).
i went in the car and tried to set the gains and barely any voltage was read from my dmm. i stuck in my bass mekanik cd and got a bit reasonable voltage, but they only go up to 99hz.
sorry for the long read but what am i doing wrong when burning, i also tried windows media player's burning program. thanks
windows built in burning softwares are low quality burning softwares. You want to make a music CD so you want to use something like Nero or Roxio Easy Media Creator.
sounds to me like the files are being eq'd before they're burned
use a standalone burning program to make sure it's being burned correctly (with no processing)
CDburnerXP pro is a good free program
try it out, and see if the same thing happens.
dleccord
dleccord
Sacramento
Megalomaniac
