Catalatic converter
Can you hear anything rattle under the car idle/ or accelerating?
If so there is probably junk in your cat. You can possibly try to seafoam it.
A misfire on cyl 3 won't affect it to were you would notice at idle. If you put it in drive and push the brake almost to were you'd powerbrake if WILL misfire it there's a problem with your coils. As far as your cat goes have the shop check it out. They will know but don't let them screw you around. Take it to two or three shops to get several opinions,
but i havent noticed a misfire?? Engine wise it seems to run fine @ idle.. Doesnt a misfiring cyclinder affect your idle?
a constant misfire can damage your catalytic converter...
you should probably clean up that misfire before you tackle replacing the converter.
I dont think the misfire code is anything major, i think i just need to clear the codes.. Still wouldnt cause my shifting to be jacked up though right?
Yes, pre gapped plugs...
i dont trust "pre-gapped" plugs. id recheck everything you did if it were me.
secondly, if you just started having a misfire i wouldnt blame it on taking the cat out. but certainly dont put a new cat in unless you can fix the misfire first.
If im on the gas, full throttle its fine. Shifts great. The problem im facing is at medium acceleration. Im getting a shutter/bog/bouncing idle. Sometimes it feels like it doesnt want to shift. its really bad @ the 45-50 gear shift.
its only at that speed? ****** shifting is going to be controlled by the valve body (if you've ever seen a valve body its got valves to direct pressure which will shift gears) so if you have shifting issues that are always present in the same upshifts it could point in that direction.
how many miles are on the car (assuming these are all original parts?)?
edit: haha, what the **** was i talking about? balls and shit?
i think the same thing has happened to my car, except i am not spending any money to fix it, if it dies it dies. I first noticed rattling in the cat and then it stopped and i have terrible idle and shifting problems. It might be my ******, but i am pretty sure it has a lot to do with a horrible rusted cat.
bad @SS chevy
bad @SS chevy
ohio
bad @SS chevy
