Hard starts on my 91 Acura Integra
montx
MO
Because I don't feel like retyping the whole ordeal, here is a PM I sent someone:
" I've been here on the forums for quite some time but I've never really spoken to you before this as there was no real reason :p I know you deal with tuning, and you do it well, so I thought I'd send you a PM asking for some advice about my current situation.
For the longest time now I've had this weird problem whenever I start the car. My vehicle is a 91 Acura Integra ( a lot of same stuff engine wise ). My starts are really sloppy. When I start my car it either has a really slow start and it seems it has to struggle to get to the cold idle RPM. Other times it'll start relatively smoother but the engine still misses. Now keep in mind the only time I see a real big problem with the engine's performance is when it starts. Although I have noticed that when I drive right after starting it sometimes it'll randomly bog down heavily. Or, if the problem happens when Im idling, the rpms will drop and raise 100 or so, then the engine shoots up to 1500 RPMS and drops to normal 800 and no more problems occur.
On other occasions A CEL will come up w/ code 43 - fuel delivery system. In terms of maintenance, in the half year I've had it I've replaced the Timing belt, water pump, spark plugs, wires, dist. cap, rotor, and the ICM. I've also replaced the VC gasket and the fuel filter.
On another note, when I did the ign. timing after changing the belt, I got it spot on ( it's supposed to be on the black like on the pulley, IIRC ) but I forgot to jump the service connecter. How will this impact the performance?
Also, the car gets MUCH better MPG if I use premium, when it's only required to use regular.
On regular I get around 20, with premium ( 91 ) I get 30! lol Do you have any advice as to what may be wrong? I have no clue.
PLEASE, please help
Steven "
Any help would be appreciated... This problem is just bugging the shit out of me, honestly! Today as I went to start the car, it would just rotate but wouldn't turn over. Only after I mashed on the gas and then it started...
Meh I searched there and am an active member on both team-integra and g2ic.com //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Integras don't have MAFs, but thanks for the help //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Have you checked the grounds on your car? I had this issue with my MR2 turbo not too long ago and it was a combination of bad grounds, and it was after hard rain so I had water in my spark plug wells...
-Aaron
montx
montx
MO
Ferendon
