Carpet application help...anyone?
3M makes some amazing contact spray adhesives that work very well and set quickly. My personal preference is towards contact cements because I know that once it dries, nothing will be able to take it off. The others adhesives' bond strengths can be affected by temperature and other factors.
Originally posted by Heresy 3M makes some amazing contact spray adhesives that work very well and set quickly. My personal preference is towards contact cements because I know that once it dries, nothing will be able to take it off. The others adhesives' bond strengths can be affected by temperature and other factors.
Dap weldwood. Make sure to put it on both the carpet and the box. Then let it tack up good before you try to put it together. If you do this you will never have a problem with the adhesive coming lose. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by XSNOIZ I'm worried about it "bleeding" through the carpet...anyone think i'll have any problems???
Don't brush it on so thick and you will not have a problem. I can't stress the importance of letting it tack up before putting the two surfaces together. Let it tack and you won't have to worry about bleed through. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Where do you get it? Any hardware store?
XSNOIZ
XSNOIZ
South County
taylor
