car wont start
Scoobydoo
POOPSIE McSQUIRTYSHORTS
it has been -10 to -40 below here the past few days and now my roomates car wont start. it barely even clicks when she tries to start it. i checked the battery and it is showing 12.7 on the dmm
can i check the starter using a dmm? hows i do dat?
thanks
Knock the starter a few times with a hammer or rubber mallet while someone tries to turn the key. If it starts, starter/starter solenoid is bad, replace.
Starter could be a bit frozen up. This 0 degree weather makes my starter go very slow, you can hear it, but somehow it manages to turn over. For sure check out the starter.
no luck, tried cleaning off the battery contacts with sierra mist and smacking the starter as best i could
told her to just buy a new car since it is a POS anyway
the car is frozen.... along with oil so you wont get shit until the engine warms up. take a foil pan and some charcoil. light the charcoil until the coal burn down to red hot and slide it under the car and under the engine for about a half hour and it will warm it up enough to start.....btw im not bullshitting this works its a trick truck drivers use when our diesels dont start in cold weather
edit: also when ure done warming it make sure u have jumper cables or batter charger hooked up so it gets plenty of juice
ya i did notice her oil is really low so it crossed my mind that it could be frozen
unfortunately i dont have any oil to add to it and it is snowing here and the roads are too crappy to go out for some
dont add oil just take a tin baking pan and do the charcoil trick. you dont need to add oil. on our semis we have engine block heaters. basically we plug the truck into any outlet in freezing temps and the block heater keeps the engine around 160 degrees non stop and cyccles the oil and coolant through entire system to keep warm. once you lay the hot charcoal under there its the same concept. the engine will get to optimal running temp and should crank with ease
also what you need to look for to is to make sure the fuel lines and tank didnt gel up. if they did....your gonna have to pay a tech some serious dough to ungel them or.........wait till summer/....but seriously if u have some charcoil and a thin tin pan try it
unfortunately i dont have a tin pan and charcoal briquettes laying around either, would still need to go to the store
what if i microwave the oil to heat it first;)
Scoobydoo
Scoobydoo
DINGLEBERRY
Scoobydoo
michigan born
    May 14, 2026
michigan born
    May 14, 2026
