Car keeps jerking/stuttering
LazyRider
Ok so to start it off I have an 03 grand marquis about 106,000 miles. Sometimes when I accelerate up to like 50mph my car starts to like jerk or stutter a bit but after I push the gas some more it accelerates and rides fine. Also happens when I slow down a bit and then hit the gas it stutters more.
This is what I've done to the car since this started:
New Tires
New Spark Plugs
New Fuel Filter
Oil Change
Air Filter
Suggestions?
i have a very similar problem and i'm going with faulty fuel pump. i haven't fixed it though, so i'm not 100%
but you should have a code. i dont because my chip eliminates the CEL so i dont get codes //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Yea I tried the code thing at a shop nothing came up. My check engine light did come on before and my car stopped but then I turned it off and turned it back on and it went away so I took it to the shop that same day and tested it and nothing came up. This sucks
prob transmission if no codes are being thrown.
This is what I thought...and the fact it is based on speed. It could possibly be ignition coils, but I am betting on the transmission solenoid because it is around where the ****** shifts. There is a thing called the TCC solenoid that goes bad. Another problem it has when this is going out is starting again after getting off the interstate. It "acts" as if the car is still in 3rd, 4th or whatever.
LazyRider
LazyRider
Internet
gnatnoop
