car battery
can i run a regular car battery in the trunk for my amp?? im runnin a kicker zx300.1.. wound it be safe to do?
Um, probably not the best idea in the world. As others have said, if it tips it'll leak and then you'll have a problem. If you are gonna run a secondary battery, go dry cell, either an optima yellow top, stinger (I have the Stinger SPV44 as my secondary.), or an increasingly popular Kinetiks battery. But as silvercookie said, with that small of amp you probably wouldn't really need a secondary battery. I'd make sure to do the Big 3 and then go from there.
building a box would be mounting it and you cant seal a battery its either sealed or not (optima makes sealed batterys) but like silver said ur amp doesnt really need that just upgrade ur front battery
if you want another battery get a small agm one like a kinetik hc 600. they are small, dont leak, dont corrode, and you can mount it anyway you want. they also are good for supporting up to 600 watts
BASSINMYSUBS
BASSINMYSUBS
eminence/louisville, ky
audiolife
