Car audio and marijuana
I'd love to see a legitimate scientific study relating LSD use to Parkinsons disease.
I Didnt say it caused parkinsons disease I said it caused things LIKE as in similar to parkisons disease. Now smoking crack off of tin foil can also give you same type of symptoms from the tin foil actually accumulating in your brain over a period of time.
From things I have read and seen from variuse sources.
Once again, I'd like to see actual data proving this. It seems very similar to the whole "acid makes your brain bleed down your spine" myth.
I have no actual data on hand but if you would like to see a good documentery movie over what some say the creator of LSD go check out Timothy Leary's Last Trip. As far as the "brain bleeding down your spine myth" I think people may have come up with that because after tripping for several hours it feels like your spine is turning into mush or somthing, Giving you severe back aches that are centered down the spine. I am not sure why it does that but I wouldnt think that would be harmful since it goes away with time. Speed can give you back aches to over time while on it but that is probably from just being up for days and not resting your body.
You don't get Parkinsons disease, but there are drugs my college biology teacher had brought up that with abuse fry neurons and receptors I belief which can be irreversible with abuse and cause something like Parkinsons. There are actually natural chemicals that your body releases to keep your muslces functioning properly. And I belief these receptors and transmitters get messed up from the drugs causing the muscular problems.
Here is a new theory that I thought of that may be the reason why the U.S. doesn't legalize weed. If they legalize weed it takes the money away from the black market. So the black market must do something else in order to make money. So the black market pushes heavier drugs that the U.S. actually fears will cause more problems. So the U.S. may be attempting to keep the black market happy and trying to make weed the black market drug of choice to minimize the heavier drugs from coming in.
Up to a life sentence?!? Just for what you could fit in your pocket? Wow, I don't even think cocaine penalties are that high, except that guy in "Blow" got 60 years, but that is because he had a record. I'm sure you'd have to get caught more than twice to get a life sentence. I believe you though, because it is powerful stuff that should probably be kept under control. You're right that it isn't physically addictive, only pyschologically addictive which is good. If the punishment for getting caught is that great then I can see why nobody hardly has it around here. Now, marijuana on the other hand, they don't do $hit if you are a juvenile, and basically nothing if you are not, so getting caught is not a big deal with that. If they really wanted to stop it, they should probably treat it as harshly as the other drugs.
I think it is up to a life sentenc with either a 100 doses which would be like a sheet or a 1000 doses which would be like a book with the intent to distribute. Some places may consider distribution of LSD attemted manslaughter or somthing like that. anyway a person can put a book of acid in their pocket. That much LSD is very dangerous to handle.
alot of people smoke weed,car audio has nothing to do with it
I think the percentage of the population that tokes up is alot higher
than you would imagine -
If i had to guess Id say 50% have tried it( and I think thats low),25% smoke it occasionally and 10% smoke it regularly
What a retarded thread lol, no offense //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
EDIT: an old *** one too //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Annex
Annex
Ohio
faulkton
