car amp and sub in the house!??
hey got a couple of questions that i hope can be answered i have a 15 inch orion xtr pro one of the more pridefull peices of car audio that i have. it was one of my closest freinds and he died not long ago in a car crash now to my point he allways wanted to hook it up in his house just once but now he cant so i have been researching it online so i dont mess anything up now i only want to do this for like not even a day there are a couple of people that have done it i know how to hook up an amp and i have a car battery sittin on my sub box next to the amp that i got from my buddy i know the GND to -NEG REM+ along with the power to+ terminal here is the kicker its a four channel amp mono so it has four audio wires besides the power sorce enyone have any sugestions on the best way to forefill this epic jorney
Your friend wishes you used the search button... //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Yes, this is tasteless but maybe he will get the point to use the search button next time. I also edited it to a little more PC. You guys happy now?
i'm sick of alot of things on this forum...like people putting ****** crap in threads and stuff like that but i don't worry about it. As long as this forum exists...people will not use the search button
I think I got flamed once for not searching...
Guess what I do before I post a new thread!!!!
I guess some people learn and others are too dense...
What is a four channel amp mono?
I will go over this for you.
Power is simple:
(+) Red Positive goes to the (+) on the battery.
(-) Black Negative goes to the (-) on the battery.
Following me so far?
If so proceed to to the next step.
Since you most likely are going to be using a source of signal other than a headunit you need to 'trick' the remote. Don't worry it is as simple as using the search button.
Get a switch. Run a wire from the battery (+) Red Positive to the switch. Now run a wire from the switch to the amplifier and put it into the "remote" location.
Now you have power.
Here is your big issue however. You have a subwoofer. You also have what sounds like an amplifier that should be used on High Frequencies. Now listen and read this carefully. YOU CAN NOT MAKE A 4 CHANNEL AMPLIFIER RUN IN MONO, YOU WILL DAMAGE THE AMPLIFIER! Sometimes you can bridge it to stereo, but I have only seen one amplifier ever that you can double bridge, and it was NOT car audio.
So here is what you should do.
1) Stop everything.
2) Tell us more information about what each part is and what exactly you want to do. So what we can advise you on what to do.
3) Go to http://www.bcae1.com/ and learn.
2 and 3 can come in either order.
slipperyirish
slipperyirish
south boston,ma
joetama
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
